When i had levered the arm all the way across i noticed it was stopping on/against the bell housing to gbox adapter plate ( and not to the edge of the arm's hole / void ) ,AND even though my wife could turn the flange quite easily there was still a light rubbing sound (shhh shhh ) between clutch and flywheel face , while its still all out ,ive pulled the box from the back of engine now , I feel it would be rude not to file out about 3 mm from the adaptor plate and let the arm travel that little bit further , has anyone on here had any clutch disengagement problems with the T 5 box , and does anyone know what the ratio of the arm is ? I:e does 1mill of extra throw on the outside add 10 ft on the inside ?? (WEll you know what I mean )
Cheers for any ideas
