I'm looking into producing a stainless hardware bonnet assembly kit, would just like to confirm thickness and diameter of shims between center panel and wings.
Julian.
Bonnet Hardware
#2 Re: Bonnet Hardware
Hi Julian...not answeting your question but AJ Auto make lots of E type parts in stsinless http://www.ajautocraft.co.uk/default.htm
#3 Re: Bonnet Hardware
Julian,
The bonnet centre panel to wing spacer washers are 19mm in diameter and 2mm thick.
Hope that helps,
Hope that helps,
#4 Re: Bonnet Hardware
Should they be metric?
#5 Re: Bonnet Hardware
mgcjag wrote:Should they be metric?
You couldn't resist could you?
Yes they are imperial.
3/4 inch diameter ( 19.05mm)
5/64 inch thick. ( 1.984mm)
Happy?
#6 Re: Bonnet Hardware
Sorry Simon.......it was an offer to good to turn down
#8 Re: Bonnet Hardware
Don't worry Steve, manufacturing to the nearest 0.05mm would be precision engineering compared to some E type bits I've bought recently. They seem to work to + or minus 5 to 50mm and then assembled the stuff blindfolded and one handed while hungover.mgcjag wrote:Sorry Simon.......it was an offer to good to turn down
