I'm having to replace my windscreen due to a large crack and wondered if anyone had any advice as to the best type of glue to use to stick the interior mirror back to the new glass.
This is a picture of the mirror as it came off the old glass. Totally original as far as I can make out for a S2 2+2. The gluing area is slightly wider than a penny in diameter.
Cheers,
Nick
S2 2+2 interior mirror
#1 S2 2+2 interior mirror
- Attachments
- Interior mirror1.gif (136.57 KiB) Viewed 2963 times
Nick
1969 S2 2+2
1969 S2 2+2
#2 Re: S2 2+2 interior mirror
I had good success with some Evo-Stik 320130 2ml Rear View Mirror Adhesive.
Available on Amazon -
I am sure there are other places also
-Mark
#3 Re: S2 2+2 interior mirror
I used the UV-hardening adhesive. Very strong and crystal clear result. It's very fluid and runny, but cleans off easy. Hardens in daylight, in my garage it took about 2 days to harden out. You could get a UV lamp and harden in minutes. I used UHU Glas. I have the same mirror. You have to take the mounting base off the mirror, and fix it in place with tape till glue has hardened.
Martin Scherz
Late S2 1970 OTS US LHD
