Thermostat (again)
mystery type
#1 Thermostat (again)
Post by mystery type » Thu Feb 02, 2017 1:26 pm
I am about to fit a new header tank as mine has rusted through, and whilst I'm doing this job I want to fit a thermostat.
After reading the many topics on this I am confused on which thermostat to purchase.
I have a series 1, 4.2 engine. can anyone point me to the correct part.
I am buying the tank from barratts but cant seem to see a thermostat listed under cooling :roll:
The bypass hole is 12 mm from the face.
Paul 1967 S1 2+2
#2 Re: Thermostat (again)
Post by Heuer » Thu Feb 02, 2017 2:01 pm
If you look at the bottom of the page you will see the Forum has automagically searched and found relevant posts on your requirements. viewtopic.php?f=3&t=8478
If you buy from SNGB these are the correct part numbers:
Alternatively Wat-Jag can supply a sleeved thermostat.
mystery type
#3 Re: Thermostat (again)
Post by mystery type » Thu Feb 02, 2017 8:01 pm
Thanks David,
I got confused as I had read so many conflicting posts, such as the one below where someone had suggested
that same thermostat from sng barratt, but you said that wouldn't work.
anyway I will purchase that so many thanks.
Postby mgcjag » Mon Feb 15, 2016 4:49 pm
As i posted previously from SNG http://www.sngbarratt.com/ProductDetail ... df6f288830 just check to make sure its correct
Postby Heuer » Mon Feb 15, 2016 5:05 pm
Actually Steve that SNGB will not work because the sleeve is positioned just below the upper plate of the thermostat whereas the original version has the sleeve is positioned 1 inch lower. Hence I did not recommend it - it has a * after the part number meaning it is not to original specification:
Paul 1967 S1 2+2
paydase
#4 Re: Thermostat (again)
Post by paydase » Fri Feb 02, 2018 11:57 pm
I also am confused with all these specs, models, OEM or repros.
I have an S1 3.8 and I intend to replace my thermostat while doing restoration works on my cooling system.
I have not yet opened the thermostat housng but it looks "standard" for the 3.8 engine.
When I look at what SNGB offers there are three different thermostat models for my car:
- C3731/1* which is presented as a repro 70-75°C;
- C27650 whisch is sold as "standard" 74°C; and
- C27650 which is the OEM 74°C.
Funnily, the OEM is the cheapest, then comes the standard and the most expensive is the repro!
I am tempted to purchase the OEM of course but can anyone confirm that it's the right one as all the models presented have a different look.
Please advise
thermostat housing.jpg (211.71 KiB) Viewed 3841 times
Serge
1964 (3.8) FHC
1961 OTS
#5 Re: Thermostat (again)
Post by mgcjag » Sat Feb 03, 2018 9:10 am
Hi Serge.....everything you need to know about thermostats including some good diagrams on how they work..viewtopic.php?f=3&t=8478
ralphr1780
#6 Re: Thermostat (again)
Post by ralphr1780 » Sat Feb 03, 2018 9:56 am
Serge, have you been facing heating issues or suspecting that your thermostat is not working properly?
The one I have fitted on the 3.8 to replace the wrong one found during resto is the waxstat C3731.
Car is not yet on the road, but static tests in the courtyard with IR gun lead to believe that system is working properly.
Ralph
'69 OTS + '62 OTS - Belgium
paydase
#7 Re: Thermostat (again)
Post by paydase » Sat Feb 03, 2018 12:52 pm
Tank you for the useful comments.
Steve, I had read the thread you linked but it is quite complex to understand what is what at the end...
I will read it again.
Ralph, thx for the advice and good idea making IR tests. Who knows, maybe my thermostat is still good ;)
Serge
1964 (3.8) FHC
1961 OTS
