There was a promising thread here :
viewtopic.php?f=4&t=14638
but the pictures seem to be dead.
My car always had the heater-flap control cable coming out into the engine bay through the "sister" hole just above the water-valve cable.
The routing isn't terribly satisfactory as it then has to negotiate around the washer-bottle before being fastened to the heater box.
My question however concerns the spring that is, I imagine, meant to give a positive flip-flop to govern the Open-Closed choice, such that it holds it either Open or Closed with some spring pressure.
As you can see, I have fudged a spring to give the desired effect, but it will have to have a significant portion of dead-straight (my twisted wire, and YES - I did stab my finger, as all lockwiring sufferers will recognise
Does any of this look right, and does a spring indeed exist that is meant to operate with an arm such as mine - I'm not even sure if it's original ? Tho' it does look pretty much like this C19761.......
Robey shows spring C15587 as being parallel for almost the whole length, which looks like it won't cut it.
EDIT NUMBER ONE - actually, whilst it looks like the Ebay one, mine must be from another model, or even perhaps off another car, as it's not kinked to get the spring-post sideways in the right direction.
It looks like it was designed to fit a shaft with a flat on it, whereas my shaft is just round - can someone confirm that's correct ?
but I've just machined the peened-over zone off, and switched the pillar around to the other side, plus a bit more of a kink .................
It'll do until I find the correct part.
EDIT NUMBER TWO : and I could have avoided wasting everyone's time
This one appears to show the heater-flap cable running like mine, BUT it's showing a LHD car - was it different on the RHD models, I wonder ?
