#1 Fuel filter - spraying fuel
Posted: Mon Mar 06, 2017 6:15 pm
Installed a Mangoletsi EFI system on the 4.2 engine (XJ6 sourced) in my 1966 series 1 2+2.
Switching the ignition key to on, I can hear the clicking of both fuel pumps for say 5 seconds.
The fuel filter bowl will fill to about 80% full.
Push the starter button and the engine turns over.
Happy days after 2 years of restoration.
At least until I noticed that the rubber gasket of the glass fuel filter had failed and the fuel pressure caused a spraying of fuel all over the walls in my garage (ok, self build car port...).
When I switched the engine off, the fuel filter bowl was full.
Bought a replacement rubber gasket, unscrewed the glass fuel bowl which caused some hissing (pressure escaping?) and installed the new rubber gasket, hoping that this would solve the problem.
No such luck. The 5 second clicking filled up the fuel filter bowl to about 80%, with no leaking.
Pushed the starter button, and this time, since I was standing next to the fuel filter, I got a proper showering in 95 octane, and not the wall...
Can it be that I am overtightening the fuel filter bowl and a such deform the rubber gasket? Probably, but is there a way to know the correct tightening without messing up the gasket?
Or, reading some other posts, could it be that I have an "air lock"?
Any suggestions most welcome!
