in a quest to service all of the parts in the restoration I looked in to taking the handbrake assembly apart last night
or
the problem I am accounting is that set screw part 31 screws into what I am guessing is a captive nut or rivnut within part 30....but the nut is spinning within part 30...and I am struggling to figure out how to stop it rotating
I also have a suspicion the rivnut is aluminium so there may be some bimetallic corrosion between the two which is not helping the situation
I realise I don't "have" to do this, but the parts are rusty and oily so any form of blasting or dipping will leave debris or fluids within part 20 which isn't ideal....plus until I can get part 29 separate from part 20, I cannot loosen spring part 21 which means I cannot get part 17 off....so it all seems to hinge on parts 31 and 30
offers of help welcomed
thanks
Jonathan
