working on the Stromberg carb's of my '71 V12 I found the next confusing item (sorry).
On my car between the carburettors and the inlet manifold there was one paper gasket and a thicker gasket block.
Is the paper gasket really necessary? If so I think there should be 2 per carb.
Gasket-Block-Gasket.
In the carburettor overhaul kit from Burlen there are 4 of the gaskets so I think they should be used.
But if so, are they necessary between carb and block or between block and inlet manifold.
Sven
