bearings on rear hub
265bhp
#1 bearings on rear hub
Post by 265bhp » Mon May 29, 2017 8:29 pm
hi
I was using a puller to remove what I thought would be the full hub bearing...however I succeeded in removing solely the outer bearing race...leaving the inner ring firmly on the hub....
at least I could remove the oil seal which was pretty lose....but now I have a problem....
I am now struggling to get a purchase on this inner ring
can In leave it in place and use only the outer race and needle bearings of a new bearing....or is there a trick to the inner ring
yours hopefully...!
Jonathan
#2 Re: bearings on rear hub
Post by abowie » Mon May 29, 2017 9:38 pm
You need to remove it.
Use a cold chisel with a nice sharp edge between the bottom of the bearing and the hub.
If that doesn't work, try some heat as well or just cut it off with a Dremel.
265bhp
#3 Re: bearings on rear hub
Post by 265bhp » Mon May 29, 2017 9:53 pm
Hi Andrew
Figured as much...was wondering about the slicing option...at least I now know what options I have
Many Thanks
Jonathan
#4 Re: bearings on rear hub
Post by mgcjag » Mon May 29, 2017 10:00 pm
Hi Jonathen...or you need a bearing seperator https://www.cromwell.co.uk/shop/automot ... GwodPCgKag
JagWaugh
Switzerland
#5 Re: bearings on rear hub
Post by JagWaugh » Tue May 30, 2017 5:14 am
This is one of the jobs where you need a wedge type bearing puller, as Steve links to. Diff output shafts are another job where you need it.
Hugo
#6 Re: bearings on rear hub
Post by Hugo » Tue May 30, 2017 7:41 am
I have one of those pullers you can borrow - you must be somewhere near me - I'm in Horsham West Sussex
265bhp
#7 Re: bearings on rear hub
Post by 265bhp » Tue May 30, 2017 7:44 am
Thanks Steve....will purchase one of those
#8 Re: bearings on rear hub
Post by mgcjag » Tue May 30, 2017 7:47 am
Just make sure you get one that fits....i put up the link just to show the type you need not the actual model to get
#9 Re: bearings on rear hub
Post by chrisfell » Tue May 30, 2017 9:00 am
Cold chisel and a grinder, but be careful.
Use the cold chisel as suggested. If that won't move the bearing race, then carefully cut a diagonal slot in the race. Don't go all the way through. Then hit the slot with the chisel. If it doesn't crack cut a little deeper. Repeat until it does split.
I'd try to avoid the wedge puller as it can damage the hub, and that damage will need to be dressed out.
Hugo
#10 Re: bearings on rear hub
Post by Hugo » Tue May 30, 2017 9:05 am
Why would it damage the hub? It's designed for that job. Unless you do the clamp bolts up like a gorilla of course.
rfs1957
#11 Re: bearings on rear hub
Post by rfs1957 » Tue May 30, 2017 9:13 am
Splitters like the wedge-type can and will damage the rest because they're nothing more than slow-motion cold chisels that are attempting to force their way into a marginal gap ; one of edges of the interface has to give, and it's not going to be the hardened steel bearing core.
They are designed to get behind the outer race of ball-races, which by definition have a bit of slop, and also have radiused corners to aid fitting - and removal, hence the tools in question.
The Timken-type core has neither of these.
This type of removal is a very common problem on the lower headstock taper-roller bearing core on motorcycles, which remain stuck on the lower-yoke stem with no asperity or edge to get hold of.
Our standard industry method is to get a MIG welder, obviously protecting neighbouring surfaces from any spatter, and weld two bits of something - anything - on, diametrically opposed, that will enable you to get a good tug underneath some sort of edges with a puller.
A suitably-sized old ball-bearing outer or inner from your Magic Box (I never throw bearings away for precisely this reason, and just punch out the cages) can make a good martyr for this.
That grip, plus the thermal shock and expansion, will make most - all ? - bearings a doddle to remove.
With the stem being so long, and pullers that deep being thin on the ground, on bikes it is often sufficient to just whack a good blob of MIG on the back edge, and then immediately use a cold chisel, even at quite an oblique angle, whereupon the race will pop off.
This "dead-simple-lazy- botch" might well work on the Jag bearing, at least sufficiently to be able to get the legs of the puller into place, or - why not - a bearing splitter which is fine once the gap has opened somewhat.
Hugo
#12 Re: bearings on rear hub
Post by Hugo » Tue May 30, 2017 9:40 am
rfs1957 wrote:Splitters like the wedge-type can and will damage the rest because they're nothing more than slow-motion cold chisels that are attempting to force their way into a marginal gap ; one of edges of the interface has to give, and it's not going to be the hardened steel bearing core.
Oh I see what you mean - I was thinking of using it as a puller on the outer lip (the smaller one), not as a splitter between the bearing & hub. In fact I've never used these things as splitters - only as pullers. You don't need a lot of purchase to drag a bearing off.
#13 Re: bearings on rear hub
Post by mgcjag » Tue May 30, 2017 11:05 am
They are nothing like cold chisels and a hammer.....one slip with the chisel or hammer and you have problems...i have used both and know which one i would use first
265bhp
#14 Re: bearings on rear hub
Post by 265bhp » Tue May 30, 2017 12:44 pm
All good advice guys,thanks..I will try to get this new splitter to grip under the top ridge/edge of the bearing ring...then try and get it to pull the bearing off....my 3 pronged puller is too "adjustable" to get a decent purchase
#15 Re: bearings on rear hub
Post by abowie » Tue May 30, 2017 11:34 pm
265bhp wrote:All good advice guys,thanks..I will try to get this new splitter to grip under the top ridge/edge of the bearing ring...then try and get it to pull the bearing off....my 3 pronged puller is too "adjustable" to get a decent purchase
You may find the splash guard interferes with the bearing splitter. This is why i usually use a cold chisel. It is unusual to require a huge amount of force to get these bearings off.
265bhp
#16 Re: bearings on rear hub
Post by 265bhp » Sun Jun 04, 2017 8:05 pm
bearing splitter worked a treat....clamped it around that top lip of the bearing ring, placed hub upside down on a block of wood and belted the splitter on all 4 corners one after another
3 minute job per hub
thanks all for the help..!
Jonathan
Hugo
#17 Re: bearings on rear hub
Post by Hugo » Sun Jun 04, 2017 8:36 pm
I would use it the other way round - so you don't have the chamfer uo against the lip.
Durango2k
#18 Re: bearings on rear hub
Post by Durango2k » Sun Jun 04, 2017 8:49 pm
I hammered some carpet cutter blades into the slot, and after about 2 or 3 a chisel could be used. Iirc even the blades were re-used again after this.
Carsten
