#1 Ongoing running problems
Posted: Mon Jul 20, 2009 6:52 pm
by andy8688
Thanks to everyone replying to previous topics.
The problem I have with my car is after a few miles it develops a judder like running out of fuel, then engine backfires, Im talking pedestrians taking cover, then engine stops.
If I leave the car for about one hour it starts fine it will go for about 3 miles, I have checked everything people have suggested, the latest one was the earth wire connected in the distributor, it turned out not to be that. I have had it tuned middle carb piston is a little sticky but assured would be OK.
Any more suggestions, my engine and carbs were all rufurbed 3 years ago.
Andy
Posted: Mon Jul 20, 2009 7:31 pm
by Car-Nut
Hi andy,
you need the Haynes manual.... My new bedtime book
incorrectly gapped plugs
faulty coil
mixture to weak
#3 Re: Ongoing running problems
Posted: Mon Jul 20, 2009 8:01 pm
by 1954Etype
andy8688 wrote:Thanks to everyone replying to previous topics.
Andy
Andy,
run it with the fuel filler cap off - they are vented and if blocked can cause problems (not the misfire though!). Worth a go. Try replacing the condensor.
Posted: Tue Jul 21, 2009 4:28 pm
by p1vickers
Andy
Have you replaced the condensor in the distributor? Is the coil new? is the fuel pump delivering fuel when the engine stops?
1967 2+2
Posted: Tue Jul 21, 2009 5:08 pm
by Heuer
Andy
It might be worth giving a summary of what you have done so far.
Posted: Tue Jul 21, 2009 6:58 pm
by andy8688
I have checked all filters, replaced plugs, leads, dizzy cap, points, condensor, coil and checked timing, I have had the carbs tuned and balanced, apart from the middle piston sticking slightly.
I was talking to someone today who owns a series 1, and he had a similar problem it turned out to be a faulty coil, so I have ordered another, will let you know how I get on.
Andy
Posted: Tue Jul 21, 2009 7:48 pm
by Bill Molloy
I had something like that many years ago on a Ford Capri - it turnd out to be the condensor. Also had something like that on a much older car even earlier in my motoring youth and changing the coil and condensor cured it
Posted: Tue Jul 21, 2009 8:58 pm
by christopher storey
It also sounds typical of rotor arm failure, where when hot the arm shorts out, and once it has all cooled down, the earthing pathway closes off . This is a result of poor material in pattern as opposed to genuine Lucas rotos
#9
Posted: Sun Jul 26, 2009 5:30 pm
by andy8688
Thank you to all your all of your replys, the problem turned out to be a very old and tired wire which connects to the negative of the coil, and down to the connector on the plastic bit which fits between the dizzy and the cap part number RTC175.
What a transformation, so simple, but taken a long time to solve.
Andy
#10
Posted: Sun Jul 26, 2009 8:26 pm
by Car-Nut
andy8688 wrote:Thank you to all your all of your replys, the problem turned out to be a very old and tired wire which connects to the negative of the coil, and down to the connector on the plastic bit which fits between the dizzy and the cap part number RTC175.
Andy
Glad you sorted it Andy. :)
Its little things that can really bug you though...
