New/old Pistons
Tricky1.5
#1 New/old Pistons
Post by Tricky1.5 » Thu Jun 15, 2017 11:13 am
Hi guys,
As I have inherited a project I have some 'new' old parts. At the top of my list for the engine rebuild is a new set of pistons that I estimate are 17 years old. I understand they are .003 over but I cant figure out what the compression ratio is.
If anyone with some technical knowledge or advice I'm happy to hear it.
1968 series 1.5 FHC
Jaglex
#2 Re: New/old Pistons
Post by Jaglex » Thu Jun 15, 2017 4:22 pm
From the picture it looks like 9:1, as the 8:0 pistons top surface is flat.
Ser. 1.5 DHC LHD
#3 Re: New/old Pistons
Post by christopher storey » Thu Jun 15, 2017 5:57 pm
8:1 pistons are not flat but have a dome which looks very much like the one in the photograph . 9:1 pistons also are domed , but the dome is both bigger and higher with IIRC cutouts for the edges of the valves. I do not think the .002 refers to oversize. I think that probably refers to the ring gap, and these look as though they may be .030" oversize. What is a bit peculiar is that mark at the lower part of the piston's periphery
#4 Re: New/old Pistons
Post by abowie » Thu Jun 15, 2017 9:20 pm
If I had to guess, from the picture I 'd say these look more like 8:1s as well.
I reckon that the 2 thou measurement is probably more likely the bore clearance than the ring gap but David may well be right.
Tricky1.5
#5 Re: New/old Pistons
Post by Tricky1.5 » Fri Jun 16, 2017 11:54 am
Thanks for the feedback. I spoke to the guy who did the machining on the block and head today and by measurements and calculation he says the compression ratio will be 8.94:1 with the head gasket he supplied.
I wanted something a bit closer to 8:1 but I'll run with what I have.
Hopefully it doesn't ping its head off...
1968 series 1.5 FHC
Hugo
#6 Re: New/old Pistons
Post by Hugo » Fri Jun 16, 2017 3:43 pm
How on Earth did he work that out? I know the sums are quite easy, but considering your pistons are still in a box, how could he measure the volume of the combustion chamber?
#7 Re: New/old Pistons
Post by abowie » Fri Jun 16, 2017 10:19 pm
That should be fine as long as you run 98. If you're worried you can get Cometic gaskets up to 70 thou thick off the shelf.
