Series 2 Cam Cover restoration
andrewh
#1 Series 2 Cam Cover restoration
Post by andrewh » Sun Jul 09, 2017 7:27 pm
I am just doing some work on an XJ6 for my father and want to restore the cam covers. They are a bit powdered on the polished alloy and could do with a paint. Is there a company that does these or is there a technique to regain the machined finish to the aluminium after painting them? thanks
1962 3.8 Series One FHC
288gto
Russia
#2 Re: Series 2 Cam Cover restoration
Post by 288gto » Sun Jul 09, 2017 9:28 pm
Have a look here Andrew,
viewtopic.php?f=5&t=10014&p=80742#p80742
I had mine vapour blasted first. You can get the machined ribs looking good with a long flat block with gradually finer wet and dry followed by Autosol.
andrewh
#3 Re: Series 2 Cam Cover restoration
Post by andrewh » Mon Jul 10, 2017 7:23 pm
thank you Simon. That looks like the answer. I have seen some that look like brand new and you can see the milling marks in the ribs. Of course, it may be that they are slightly re milled. I guess you would not need much more than a thou or two to remove the paint and leave an as new finish. Thats why I wondered whether some company specialising in restoring them. I would imagine, it very tricky to avoid rounding off the edges of the ribs with a sanding block.
