Easy inner fulcrum shaft seal installation
#1 Easy inner fulcrum shaft seal installation
Post by abowie » Sun Aug 06, 2017 1:57 am
I used some clingfilm wrapped around the seal pieces to hold them in place. Worked a treat.
Pity I can't actually work out how to get the picture on Flickr to show here.
288gto
Russia
#2 Re: Easy inner fulcrum shaft seal installation
Post by 288gto » Sun Aug 06, 2017 8:16 pm
Interesting idea Andrew.
Presumably you then pushed the fulcrum shaft through the thin cling film. Did the rest of the cling film come out easily enough next to fulcrum mounts?
I used sticky red grease and glued them in place but even then it was tricky despite using a dummy shaft to align it all.
#3 Re: Easy inner fulcrum shaft seal installation
Post by abowie » Sun Aug 06, 2017 9:19 pm
288gto wrote:Interesting idea Andrew.
Exactly right. Getting the leftovers out wasn't too difficult.
288gto
Russia
#4 Re: Easy inner fulcrum shaft seal installation
Post by 288gto » Mon Aug 07, 2017 12:55 am
Brilliant.
I'll add to the top tips on IRS refurbs by saying use a pair of reversible sash clamps to spread the cage slightly to ease getting the wishbones in.
Use standard unf nuts on the fulcrum shafts and drive shafts rather than nylocs and philidas nuts until you are happy everything is shimmed up and lined up. A lot easier to undo if you have to pull it all apart again.
