#1 Help in selecting seats for Series 1 4.2 FHC
Posted: Mon Mar 03, 2008 3:46 pm
by davrix
Hi, I am looking for any recommendations on what seats to fit to my Competition E Type FHC ( currently it has only one ; and I would like to fit a pair). One key consideration is to get maximum leg and headroom, as it's a tight squeeze to fit in the car already! Any advice appreciated. David
Posted: Fri Mar 07, 2008 3:08 am
by andyp
Hi David
This is going to have to be a bit of a compromise. A thinly padded aluminium racing seat from the likes of Lynx will give you the most room but I wouldn't want to go touring on one.
Basically comfort equals padding and that takes up space.
So two questions - how big are you and what are you planning on doing with the car?
Andy
Posted: Fri Mar 07, 2008 7:44 pm
by davrix
Hi Andy,
I'm over 6'1 tall, so the legs are getting in the way - i may try extending the pedal box further forward - or even the angle of the pedals, and putting a dome in the roof - bit that's a bit impractical. Initially i am indending to do some track days in the car .. and attend a few local events like the JEC london to brighton. not sure what after that - probably not long distance touring ...
Posted: Sat Mar 08, 2008 5:41 pm
by andyp
Hi David
Sounds like you are about the same size as me - I've got a 2+2 so my head just clears the roof and the extra length is useful.
I'm sure you'll manage with a lower seat. I'd be tempted to look at some of the GRP shelled aftermarket seats aimed at the boy racers - you can get recliners which mean you can adjust the rake. Don't worry about the looks just get something that fits and then get it re-trimmed to match the car.
Andy
Posted: Sat Mar 08, 2008 9:08 pm
by harryetype
Boys
I think you've been spoilt with modern luxury
I'm 6ft 3" and I fit both leg wise and head wise. I had a early flat floor Roadster which was a bit tight with the roof up and I looked like Noddy with it down.
Are you sure the seat goes as far back as it should? and have the seats recently been retrimmed as they seem to be high when they have.
Harry
Posted: Tue Jun 10, 2008 11:13 pm
by davrix
Hi, I found the solution to the seats to give me some headroom and legroom. Kirkham competition seats from Canada! Had to have the wings cut off, and the trimming redone, Advantage is the headroom gained, as the seat cushion is only 1cm from the floor. Disadvantage : not much seat cushioning! Now working on the other things .....
