#1 radius arm bush orientation
Posted: Fri Aug 11, 2017 2:51 pm
by doffo25
Ive just been congratulating myself on having successfully pressed a new large rubber bush into the radius arm using only a vice.....worked very well......only to discover that the two rubber holes arent aligned longitudinally as they should be but at a random 45deg ish....grrrr
Am I likely to encounter any problems if I leave it like this?
David
#2 Re: radius arm bush orientation
Posted: Fri Aug 11, 2017 3:29 pm
For competition work they usually re-orientate the bushes by 90° to stiffen the suspension but they usually do that to both. If one is 45° out make sure the other side is the same. No harm will come of having them both at that angle.
#3 Re: radius arm bush orientation
Posted: Fri Aug 11, 2017 5:26 pm
:yeahthat: +1 to Heuer's point . IIRC David Marks of the JEC suggests that 45 degrees is a good compromise
#4 Re: radius arm bush orientation
Posted: Fri Aug 11, 2017 6:01 pm
by doffo25
Oh thats great.....so instead of going out to the workshop and having to hack out my new bush Im simply going to open a bottle of red :bigrin:
Thank you very much for your replies.
best
David
