48yr FHC West Coast Sills Probed
#1 48yr FHC West Coast Sills Probed
Post by politeperson » Sun Aug 13, 2017 11:43 am
I was going to post this a while ago but forgot.
I had a look in my sills with a boroscope/endoscope last month.
The car appears rust free, with no rot evident, but you can never tell till you get inside can you?
Certainly when I poked around inside the bulkhead void it looked good.
I purchased on of these camera from ebay for £15 and strapped it to some brake pipe.
I drilled a 10.5mm hole and went for it.
These are the results. You may have more of an idea what is going on in there than I do. Looks a bit spooky. Bit like the film Alien.
I appreciate I shall not be winning any photography prizes. To get an image on the laptop you have to be a inch away and steering it from the rear wheelarch is tricky, I know how those guys taking pictures of the Titanic from an ROV feel now.
I could get from one end to the other.
Then I cleaned the area of the hole, sprayed a bit of satin black on and inserted a grommet.
Certainly the sills have always felt strong from a jacking point of view.
I feel some waxing coming on (after the paint).
288gto
Russia
#2 Re: 48yr FHC West Coast Sills Probed
Post by 288gto » Sun Aug 13, 2017 8:10 pm
Quite a useful tool, and because it's cheap you don't mind getting it covered in dinitrol. I used mine to make sure I'd got thoroughly in every cavity with the wax.
Yours doesn't look too bad but definitely needs a good dose of cavity wax.
The bits to check with the camera are the bottoms of the strengthening gussets below the A and B posts as these go first. You got a bit of one in a picture.
