Heater motor wiring
RobertGrieve
#1 Heater motor wiring
Post by RobertGrieve » Fri Aug 25, 2017 7:08 pm
Hello folks.
Has anyone ever seen wiring like this on a heater motor? Seems to be the only one I've seen based on googling and researching.
The red and black seem to be connected after having tested with a multimeter. I'd imagine the other two relate to speed setting from the dash - but would be grateful for any advice
Apologies for the terrible photo, I will try and take a better one. There are 4 wires leaving the motor housing, 1 black, 1 yellow, 1 green and one red.
Rob
1966 Series 1 2+2 (LHD), Manual, AC
#2 Re: Heater motor wiring
Post by abowie » Fri Aug 25, 2017 9:23 pm
Someone's put new wires in it.
I'd try putting 12v across each coloured wire in turn with the negative connected to the black.
RobertGrieve
#3 Re: Heater motor wiring
Post by RobertGrieve » Sat Aug 26, 2017 6:39 am
Thanks Andrew - will try this morning
Robert
cactusman
#4 Re: Heater motor wiring
Post by cactusman » Sat Aug 26, 2017 8:39 am
If you are using the car battery as a power source include a ten amp fuse for your tests....just in case :bigrin: :bigrin:
Mich7920
#5 Re: Heater motor wiring
Post by Mich7920 » Sat Aug 26, 2017 8:59 am
Hi Rob
I think it could help you
viewtopic.php?f=3&t=9622
Mich
Michel
RobertGrieve
#6 Re: Heater motor wiring
Post by RobertGrieve » Sat Aug 26, 2017 6:54 pm
Thanks all. Mich - that post looks like it exactly matches my issue so should point me in the right direction, I guess I'm not the only one with slightly amended wiring!!
Rob
