#1 Most Boring Door Hanging/Hinge pin Adventure in the World
Posted: Sun Sep 17, 2017 8:15 pm
The doors on my fhc have always been a bit difficult to open.
Pushing the button and pulling from the outside risked pulling fingernails.
From the inside you had to use your shoulder to get out.
Also it was obvious the drivers door had dropped 5mm or so. The doors waggled ¼ inch or so up and down when lifted at the ends.
So my weekend project was to fix this.
The first thing I did was to read the articles in the Knowledge Base.
This involved the excellent hinge repinning article and door hanging articles.
Armed with this knowledge, this is what happened on Saturday and Sunday.
First, I removed the handles, winders door cards etc.
Then, using a trolley jack with wood I supported the weight of each door. I unbolted the hinge from the post first. Removed each door with the hinges on, then removed the hinges completely.
I removed the check straps and took pictures of the hinges.
Then I ground off the pin welds and drifted out the pins, removing 2 spaced brass washers carefully when the pins were free.
Then, I reamed out the alloy part of the hinge from 7/16 to 1/2 inch, to get a tight fit on some ½ inch bright bar. Getting that right was a matter of finishing off by hand, so that the bar would tap in lightly but not bind.
I reassembled the hinges.
It was now lunchtime on Saturday.
I cleaned down the hinges, rubbed them with 800, primed them and painted them body colour. This took an hour.
I then fitted a hinge to the driver's door, mounted the trolley jack to take the weight of the door and then carefully bolted the hinge to the a post with the 4 bolts.
Using the 3 bolts undone, one pinched up method, I rotated the hinge in 2 stages so I could check the front of the door was flush top and bottom, without the leading edge of the door catching on the scuttle when closing.
I tightened the 4 door bolts in alignment with the 2 screw holes, used in the factory and shut the door.
To my surprise, with the latch removed, the door shut just over center, with perfect gaps all round. First time lucky on that side. I did notice that the window frame was a bit proud at the top. This was caused by a bottom bracket being loose (easily adjusted) and a small spilt in the door frame at the top allowing the frame to flex outwards.
Out with the welder and all was fixed in a couple of minutes.
I then noticed that the rear quarterlight was loose. The chrome pillar behind the door was waggling around, interfering with the chrome door window rails. It is held in place with 2 screws at the base. So I readjusted it away from the door to get clearance.
However, The B- post latch interfered with the door striker pin on closing- however it was positioned.
Close inspection of the B post on the drivers side revealed the latch part of the B-post was dented, so the latch was too far recessed into the B post panel and this was causing the interference with the door striker.
I screwed in a couple of unf bolts into the captive plate in the B post and carefully using a supported jemmy lever, pulled the whole B--post section including the captive plates, ¼ of an inch or so towards the front of the car.
Now the door would close all the way without the pin hitting the latch. You could just hear the wheel spinning nicely.
However, once latched, the door was sitting 3mm proud at the B-post. And grabbing the handle I could wobble the door in and out a few annoying millimeters.
So I moved the latch outward which allowed the door latching mechanism wheel to rotate onto the second cog position, bringing the door perfectly in line again and stopping the wobble.
My rubbers were not causing me any issues.
The second door was easier.
So now my doors open and close like a Rolls Royce.
What a lot of work. At least it only cost me £1.50 for some bar.
