Lumenition Ignition
StuBYD
#1 Lumenition Ignition
Post by StuBYD » Thu Jan 21, 2010 10:37 am
Have Series 1 EType and fitted a Lumenition Ignition system some 15 years ago. System was recently replaced by a garage when my car was in for some repairs. They claimed the system I had installed had packed up. Now find that car cuts out and have to waggle wires at the connector box in order to restart it. I believe it is the black wire, which I think is the earth, that is causing the problem. In an unsuccessful attempt at trying to get in touch with Lumenition, came accross a TR forum where quite a few people have experienced similar problems. Most indicated they intended replacing unit with a different ignition system. Has anybody any ideas or can anybody tell me how I get in touch with Lumenition.
stewart Edwards
Post by Heuer » Thu Jan 21, 2010 1:07 pm
Stewart
I have a Lumention Magnetronic system fitted into a Lucas 45D6 distributor and so far it has been perfectly reliable over 25,000 miles. No personal experience of the Lumention Optronic system though. You can contact Lumention here: http://www.newtronic.co.uk/ If you are considering a totally new ignition system the '123' distributor gets very good reviews, just make sure you get the correct JAG6 version.
StuBYD
#3 Lumenition Ignition
Post by StuBYD » Thu Jan 21, 2010 3:02 pm
David, Many thanks for the response. Don't really want to change system, which is brand new. Will contact supplier and see if they can assist.
stewart Edwards
on2wheels
Post by on2wheels » Fri Jan 22, 2010 10:47 am
Hi Stewart,
Sorry I don't have any experience on Lumention.
Just wanted to find out where in Devon you are?
I live around Torbay, its not often I hear of other e-type owners around these parts.
Perhaps you could send me a PM (Private Message), so that we could compare notes.
Cheers,
Nick.
