#1 SU fuel pump electronic upgrade
Posted: Tue Oct 24, 2017 1:16 pm
I have made an upgrade the SU fuel pump using a printed circuit board to stop points corrosion due to arcing.
SU fuel pump points typically corrode due to arcing from the high currents being switched during normal usage. This printed circuit board is interposed into the circuit and uses the points to feed a transistor to do the switching, reducing the current through the points by up to 100 fold and thus eliminate the arcing.
No soldering is required as the connections are made by reusing the current terminal posts in a new configuration. It is completely invisible once the end cap is put back on.
V12 cars use a twin SU pump and so one upgrade kit per pump is required.
Comprehensive instructions are included.
Postage (from UK) not inluded.
Price GBP17
Contact me via private message
Price GBP17
