Rear Hub bearings
#1 Rear Hub bearings
Post by mgcjag » Thu Nov 02, 2017 8:20 pm
Hi All....any tips re fitting inner and outer drive shaft bearings to the aluminium hub carrier.....have heard of heating the carrier and freezing the bearings to fit easier.....any advice....thanks... Steve
JagWaugh
Switzerland
#2 Re: Rear Hub bearings
Post by JagWaugh » Thu Nov 02, 2017 8:30 pm
I just use a press. The Al is relatively soft and there isn't that much interference in the fit.
#3 Re: Rear Hub bearings
Post by abowie » Thu Nov 02, 2017 9:18 pm
As Andrew says. I usually just use a hammer and a drift, although I have recently bought this which makes the job easier.
#4 Re: Rear Hub bearings
Post by mgcjag » Thu Nov 02, 2017 9:50 pm
Thanks guys.....i have a press..... Steve
265bhp
#5 Re: Rear Hub bearings
Post by 265bhp » Thu Nov 02, 2017 11:26 pm
Having just fitted new bearings to the rear hubs and bearing rings to the aluminium hub carriers without the need for any kind of press I cannot recommend the use of heat and cold strongly enough...they dropped in effortlessly
A combination of 2 hours in the freezer and 15 mins with a hot air gun for the appropriate parts and you should have the same success as I just did
No need for a press so far...
Jonathan
