#1 Rear Tracking and Toe-In
Posted: Sat Nov 11, 2017 12:30 pm
Having played about recently with the Mini's rear camber and tracking, where toe-out was giving some distinctly leery steering behaviour under hard cornering, I'm now wondering whether my E-Type's current minor toe-out condition at the back isn't responsible for (what might be) rather odd rear-steering effects.
At 11' and 4' respectively, right and left, that's between 19' - 26' and 12' - 19' insufficient toe in, if the figures I have (no idea where from) for the ideal toe-in are right - at between 8' and 15'.
It's obviously not adjustable per-se on the Jag, although it could be modified if need be, by changing the positions of the ends of the fulcrum shafts.
Can anyone point me in the direction of anything published regarding this, or offer comments/advice as to what they have lived with, or successfully corrected ?
We all chewed the cud over this in spring 2014 :
viewtopic.php?f=3&t=4991&start=20
but I there's no clear conclusion, and whilst I can see how you could crab the IRS slightly by tweaking the length of the radius arms with some clever heat/quench, the idea that - quote
The car was raised up and a Technician fired up the Oxy Acetylene and started to heat one of the rear lower wishbones Chris informed me he prefers 2-3 degrees toe-in but has had customers who prefer 5 degree. We settled on 3 deg from memory. As the heat was applied you could see the toe in changing on the gauge.
seemed to defy my understanding of what we were talking about.
Essentially, the position of the IRS fulcrum shafts dictate the "attitude" of the hub-carriers, in relation to each other, and all you can ever do is try and balance that attitude Left-Right.
So in my case, for example, with 11' and 4', I could at best hope for 15/2 or 8' on both sides.
I can now see that it never had anything to do with the radius-arms, but involved heating the lower wishbone tubes to skew their alignment - which is indeed very clever.
However, unless my Trigonometry is orders of magntiude adrift, even just 1° of toe actually corresponds to 3.5mm of movement at the rim - so 5° would be 17.5mm, and over both wheels that is 70mm of pinch at the rims, or a full 84mm measured at the tyre-wall beads !
So there's something wrong somewhere in there.
(So we're all using the same terminology and base-lines, I'm basing this on a rim radius of 200mm, a tyre-wall bead radius of 250mm, and assuming that the lateral movement that occurs at a given radius is multipled by 2 to take account of the fact that its effect is felt across a diameter, and again by 2 because the same thing is happening with the other wheel, to give an "overall" pinch which is the measured difference between the front and rear widths at a given radius on the tyres.
And considering that for low values sin = tan etc)
Does the CKL account talk about "degrees" instead of "minutes" ?
But divide 70mm or 84mm by 60 and it all seems improbably twee.
The 8' to 15' I mentioned, as having picked up somewhere, work out at between 2mm and 4mm of overall pinch measured at the tyre-wall beads, which sounds more plausible.
Somebody might like to check my maths please, while I go and fetch the blue-tipped universal adjusting wrench .............
