#1 Distributor position
Posted: Thu Nov 16, 2017 4:41 pm
by Hugo
Can anybody tell me which way the distributor body should be facing? I'm just putting my engine back together & want to get the keyway in the driveshaft in something like the correct position. I can figure out the rotor position from the old plug leads, but have no idea which way the body should be facing. At the moment I have the vacuum advance pointing sort of half way down the block, but that's just random.
#2 Re: Distributor position
Posted: Thu Nov 16, 2017 5:43 pm
Hi Hugo...have a look at page B 28 in the service manual.. (its also in the knowledge base)...its a good diagram of distributor position and fireing order.. Steve
#3 Re: Distributor position
Posted: Thu Nov 16, 2017 7:31 pm
by Hugo
I would if I had one ;)
#4 Re: Distributor position
Posted: Thu Nov 16, 2017 7:55 pm
by ETTony
Heres mine Hugo
#5 Re: Distributor position
Posted: Thu Nov 16, 2017 8:19 pm
by Hugo
Blimey I must be psychic - that's where I put mine! Thanks!
#6 Re: Distributor position
Posted: Thu Nov 16, 2017 8:22 pm
Hugo.....I took the time to answer your post as i said above there is one in the knowledge base section...but if you cant be bothered to look
#7 Re: Distributor position
Posted: Fri Nov 17, 2017 9:58 am
by Gfhug
Steve, why ever do you bother trying to help some people when you know they will either throw it back in your face or show no gratitude? :shrug: :banghead:
Especially when this information is in the manuals that EVERY E Type owner should have. :studyinggray:
#8 Re: Distributor position
Posted: Fri Nov 17, 2017 10:28 am
Hi Geoff...you know me i try to help everyone and point them in the right direction where to find the info rather than just give an answer.......its more knowledge on the forum that someone who appreciates it can use...all the best..... Steve
#9 Re: Distributor position
Posted: Fri Nov 17, 2017 1:52 pm
by 265bhp
Gfhug wrote:Steve, why ever do you bother trying to help some people when you know they will either throw it back in your face or show no gratitude? :shrug: :banghead:
totally agree....I would go so far as to say reading and checking with the Manual and the SPC is interesting reading....you know if any parts from the original car are incorrect via the SPC and the Manual gives you a fantastic sequence and methodology...bonkers of you don't take full advantage... :salute:
