Engine Removal
colinevans
#1 Engine Removal
Post by colinevans » Sun Jan 24, 2021 7:33 pm
Hi Guys
I’m just about ready to drop my engine out (through the bottom). One question, I removed the reaction plate earlier but do I need to take the torsion bars out too? Clearance looks very tight on the exhaust side, does the bar clear the manifold?
Cheers, Colin
Colin
Series 2 OTS, 280SL
johnetype
#2 Re: Engine Removal
Post by johnetype » Sun Jan 24, 2021 7:39 pm
No you can leave the torsion bars in place but wether the exhaust manifold will clear depends on what you've left connected on the inlet side.
Once it's off the mounts you can move the engine from side to side slightly as you lower it so it's the total width at any one point that counts.
1969 Series 2 FHC
colinevans
#3 Re: Engine Removal
Post by colinevans » Sun Jan 24, 2021 7:48 pm
Perfect, thanks John. The inlet manifold is off so plenty of room on that side to swing it over a bit.
Cheers, Colin
Colin
Series 2 OTS, 280SL
