#1 su carb piston lift seals
Posted: Mon Nov 27, 2017 9:43 pm
by purplefiz43
any one know where you can get these su carb piston lift seals from or will rubber o rings do the same job cheers
#2 Re: su carb piston lift seals
Posted: Tue Nov 28, 2017 7:06 am
I have used O rings when i didn't have the correct seals. You do need to have a metal washer over the top though.
#3 Re: su carb piston lift seals
Posted: Tue Nov 28, 2017 5:19 pm
Hi...whats your name..please try to put it in as a signature with your car model......not sure what part you are actually after but go direct to Burlan....they supply all parts for SU,s
http://sucarb.co.uk Steve
