Big or small
lyons
#1 Big or small
Post by lyons » Tue Nov 28, 2017 4:40 pm
With a 2 hole camshaft,the inlet side gaps are 2 at .oo4 and the other 4 @ .006.
Bearing in mind that they should all be .004 do I leave as is, or is it better to shim all to .004.
Wisdom says that they close up in service, is this correct.
#2 Re: Big or small
Post by mgcjag » Tue Nov 28, 2017 5:11 pm
If it were mine i would set them correct...... PS..can you also please give an update to your other recent post viewtopic.php?f=3&t=11611 thanks.... Steve
#3 Re: Big or small
Post by abowie » Tue Nov 28, 2017 8:00 pm
Set them correctly at 4 thou.
I can tell you from experience that an inlet set to 7 thou will be noisy.
lyons
#4 Re: Big or small
Post by lyons » Wed Nov 29, 2017 11:04 am
Thanks for all advice.
Will now set to the approved clearances.
