Spark plug lead s
dal2.0litrefrogeye
#1 Spark plug lead s
Post by dal2.0litrefrogeye » Fri Dec 08, 2017 6:54 pm
Hi . Those of you using coil pack ignition . Where did you get your leads from . I've sorted mine ish . I'm using Aacuspark for the leads and 90 degree plug caps . But annoyingly they can't supply the other ends to the coil pack (even when their motto is designing modern ignition for classic cars ???? :banghead: ) , but as luck would have it I've a set of four leads from my Duratec lotus engine . And a mate that says he has a couple of old leads I can borrow for ever . And remove the ends off . And worse case scenario I could buy a new set and butcher them accordingly. I've looked around for companies selling lead components with no luck ??? So what's everyone else done to make hybrid leads . ??
Cheers for any ideas
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
Mikael B
Sweden
#2 Re: Spark plug lead s
Post by Mikael B » Sat Dec 09, 2017 8:57 pm
Trigger wheel have conversion kits available.
http://trigger-wheels.com/store/content ... /p238.html
I have used these together with high resistance cable by meter from Green spark plug company and standard bow tie champion spark plug connectors. Works fine without problems with EDIS megajolt and coil packs
Trigger wheel also have ready made spark plug leads for coil packs.
Mikael Berg
S1 OTS-66 Carmen Red; S1.5 2+2-68 Opalescent Maroon
