#1 Spark plug lead s
Posted: Fri Dec 08, 2017 6:54 pm
Hi . Those of you using coil pack ignition . Where did you get your leads from . I've sorted mine ish . I'm using Aacuspark for the leads and 90 degree plug caps . But annoyingly they can't supply the other ends to the coil pack (even when their motto is designing modern ignition for classic cars ????
) , but as luck would have it I've a set of four leads from my Duratec lotus engine . And a mate that says he has a couple of old leads I can borrow for ever . And remove the ends off . And worse case scenario I could buy a new set and butcher them accordingly. I've looked around for companies selling lead components with no luck ??? So what's everyone else done to make hybrid leads . ??
Cheers for any ideas
