Steering column issue
Tjclare
#1 Steering column issue
Post by Tjclare » Tue Dec 19, 2017 8:57 pm
I have converted my s2 1970 etype drophead from LHD to RHD and noticed an issue with the steering column.
As the column comes through the bulk head it's very low almost touching the bottom of the the bulk head housing.
Has anyone experienced this issue? Is it something I have missed?
Any help appreciated
Tony
#2 Re: Steering column issue
Post by politeperson » Tue Dec 19, 2017 10:21 pm
I did a lhd/rhd conversion and had just the same problem. It is the composite/glass fibre item with a black rubber grommet.
It made squeak when tuning the wheel. I squirted it with WD40. Still squeaks!
Got worse when I removed the upper column spacer washers to improve knee/steering wheel clearance.
You have reminded me, I must fix it. I suppose the mounting holes need moving up so the part moves down a few mm.
#3 Re: Steering column issue
Post by abowie » Wed Dec 20, 2017 12:24 am
Common. Not sure why.
I have this in both my converted LHD car and also in my original RHD one.
You may need to relieve the bottom of the fibreglass cover or the rubber seal. Fortunately you can't see it.
Tjclare
#4 Re: Steering column issue
Post by Tjclare » Wed Dec 20, 2017 11:40 am
Many thanks for your replies it’s reassuring to know that it’s not something I’ve missed and is a common problem.
I am looking at shortening the second steering wheel bracket (around 5mm) to allow the column to raise slightly and possibly alleviate the problem.
I will let you know how I get on 😀😀
Thanks again Tony
288gto
Russia
#5 Re: Steering column issue
Post by 288gto » Wed Dec 20, 2017 12:21 pm
Hi Tony,
I managed to gain some clearance by sanding the base of the fibreglass shroud on a flat surface. Looking at your picture the mounting flange seems quite thick like mine was.
paulsco
#6 Re: Steering column issue
Post by paulsco » Wed Dec 20, 2017 1:14 pm
I had the same problem.
There are aluminium shims under the column bracket under the bulkhead which I removed to get the required clearance.
The shims were there when in LHD form, but I am not sure they are used or are needed for RHD.
johnetype
#7 Re: Steering column issue
Post by johnetype » Wed Dec 20, 2017 5:45 pm
IIRC there's a lot of movement available on three of the four steering column UJs splines with only the one at the rack pinion fixed by the bolt. If you can move the lower column downwards and the upper UJ outwards on both splines that should lift the lower column. Also worth checking that your lower column hasn't shortened slightly on its nylon shear bolts.
1969 Series 2 FHC
Hugo
#8 Re: Steering column issue
Post by Hugo » Wed Dec 27, 2017 10:46 am
That grommet /gaiter thingy is a very tight fit on my column. I reckon it will affect the steering on the road, or at least the self-centring. WD40 doesn't really help - but that evaporates v. quickly anyway. I guess it will wear in eventually?
Tjclare
#9 Re: Steering column issue
Post by Tjclare » Sat Jan 13, 2018 1:12 pm
Hi guys
Thanks for all your help I think I’ve managed to solve the problem.
I cut the inner fixing bracket down by 4mm re welted it and when bolted it back to the bulk head the column is just about dead centre.
