fuel pump retaining bolts.
Paul Jorgensen
#1 fuel pump retaining bolts.
Post by Paul Jorgensen » Wed Dec 20, 2017 9:27 am
Hi All,
I have recently removed the fuel tank from My series 1 and would like to replace the fuel pump to tank screws with Stainless Steel.
Can someone advise me on what thread these slotted machine screws are.
Paul. 1962 Series 1 roadster 850543
1965 mk 1 Lotus Cortina
1973 Triumph Stag (had it since 1982)
#2 Re: fuel pump retaining bolts.
Post by Series1 Stu » Wed Dec 20, 2017 5:27 pm
Those screws should be 3/16" UNF X 1/2" long.
Personally, I wouldn't use stainless steel screws here because they may gall and then you'd never get them out without drilling. Not something you'd want to do around fuel.
Paul Jorgensen
#3 Re: fuel pump retaining bolts.
Post by Paul Jorgensen » Thu Dec 21, 2017 12:37 pm
Thank you for coming back to me & your advice.
#4 Re: fuel pump retaining bolts.
Post by bitsobrits » Thu Dec 21, 2017 8:53 pm
Stainless screws won't gall with just a little bit of anti-seize paste.
I've replaced all corrosion prone fastener locations with high grade stainless and have never experienced galling, as I always use anti-seize. Stainless fasteners without anti-seize could indeed be gall-city.
#5 Re: fuel pump retaining bolts.
Post by cactusman » Thu Dec 21, 2017 9:27 pm
As Steve says....use stainless steel or brass. I used stainless plus copper grease...no issues...they come out looking brand new...
