Hi EVeryone
Does anyone know if there is a specific torque setting for the large bolt that attaches the harmonic damper and pulley to the crankshaft? I’ve searched through the relevant section in the workshop manual without success.
Is it a case of just tightening it as much as you possibly can?
Alan
Crankshaft damper bolt
ALAN COCHRANE
Topic author - Posts: 712
#1 Crankshaft damper bolt
Alan Cochrane
#2 Re: Crankshaft damper bolt
I am not sure where I get this figure from ( except that it is a fairly usual figure for a bolt of this size) but 140 lb-ft comes to mind
flatfloor 3.8
ALAN COCHRANE
#4 Re: Crankshaft damper bolt
Thanks Christopher.
I only have a very large Britool ring spanner that will fit. So I'm sure that after locking the rear crank boss with a spanner and tightening the bolt with said very large spanner I will have tightened it to about 140lbft. In any event the locking ring should stop it coming loose (hopefully!).
Alan
Alan
Alan Cochrane
#5 Re: Crankshaft damper bolt
I use 120lbft.christopher storey wrote: ↑Wed Jan 24, 2018 6:45 pmI am not sure where I get this figure from ( except that it is a fairly usual figure for a bolt of this size) but 140 lb-ft comes to mind
