S1 Inlet Manifold
Petet
#1 S1 Inlet Manifold
Post by Petet » Wed Jan 10, 2018 2:34 pm
Hi Sage Ones,
Could anyone advise if a series one inlet manifold and carbs will fit a series two? I'm guessing not but would just like to check.
Regards, Pete
#2 Re: S1 Inlet Manifold
Post by cactusman » Wed Jan 10, 2018 5:07 pm
Physically probably yes although if it is a manifold from a 3.8 series 1 the plumbing of the water jacket will not match the plumbing you have for the S2. A later 4.2 series one manifold will probably fit and the plumbing might be the same but I am not sure...
#3 Re: S1 Inlet Manifold
Post by PeterCrespin » Wed Jan 10, 2018 8:46 pm
All straight port head manifolds can be swapped, although three piece 3.8 types need two water passages blocked between cyls 2&3 and 4&5. If you want to swap a 4.2 triple carb ‘log’ manifold to a twin carb S2 head you need to transfer the S2 thermostat housing to the earlier manifold so you can use modern poppet tstats instead of S1 sleeve type.
