Jelly like residue in drivers footwell
jamesmatheson
#1 Jelly like residue in drivers footwell
Post by jamesmatheson » Wed Jan 10, 2018 9:28 pm
Hi everyone, popped my head down into drivers footwell when having a check over of my s1.5, 2+2 and came across a small amount of yellow jelly like substance around top of the break pedal. Anyone know what this could be or is it just for lubrication. Was a little crusty around edges and jelly like in middle. Brakes work fine. Opinions would be much appreciated
James :bigrin:
S1.5 2+2 RHD
#2 Re: Jelly like residue in drivers footwell
Post by cactusman » Wed Jan 10, 2018 9:44 pm
Probably just grease from somewhere. Brake fluid is not jelly like unless it is mixed with paint. Worth keeping an eye on the fluid level as of course you should anyway..
ralphr1780
#3 Re: Jelly like residue in drivers footwell
Post by ralphr1780 » Wed Jan 10, 2018 10:33 pm
Also check the brake fluid level for good order sake, could be your servo is leaking.
Ralph
'69 OTS + '62 OTS - Belgium
#4 Re: Jelly like residue in drivers footwell
Post by abowie » Thu Jan 11, 2018 1:32 am
This is almost certainly brake fluid leaking back from the top seal of the master cylinder. I have seen this before and it is exactly as you describe.
AussieEtype
#5 Re: Jelly like residue in drivers footwell
Post by AussieEtype » Thu Jan 11, 2018 3:40 am
I agree with Andrew - is weeping brake fluid that has dried out and crystallised.
Garry
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
jamesmatheson
#6 Re: Jelly like residue in drivers footwell
Post by jamesmatheson » Thu Jan 11, 2018 7:04 am
Ok I shall investigate thank you for your responses
James
S1.5 2+2 RHD
