Sticking the Bonnet on a Spit Rotisserie
rfs1957
#1 Sticking the Bonnet on a Spit Rotisserie
Post by rfs1957 » Wed Jan 31, 2018 12:00 pm
The bonnet's off for some cosmetics, and it seemed a good idea to make use of the left-over Mini Van spit stuff to improve access whilst painting-fettling.
http://www.theminiforum.co.uk/forums/to ... ggestions/
This shows most of the detail construction from when I did the Van.
No pretence at inventing anything here, just thought it might help someone to know how it all balances if ever they were tempted to do something similar.
All the weight is in the nose, so as long as your spider is sufficiently robust at the front, the rear-edge carries virtually no weight and with the spit-tube up almost against the rib the two mounting holes for the chrome grill are more than adequate to carry the rear mounting bracket.
I first used the 8 anchorage points for the radiator grill, with the #12 self-tappers, to just carry two separate lengths of 30 x 30 x 3 angle-iron, and then made four separate 30 x 30 x 3 "Tee" fingers which are bolted on their outside ends to these side-members, and welded (tacked in situ) onto a central collar.
(Bolted because an all-welded frame would be very difficult to dismantle and extract.)
When it's flat, the loads on the bonnet screws are in pure shear, and when it's at 90° the load is taken on the upper legs of the spider with no load on the screws, which were of course not designed to carry the weight of the bonnet.
With the tube located centrally, then, in the mouth of the bonnet, the balance is well-nigh perfect and the bonnet can be rotated with one hand, then blocked with the split-ring.
Polse7317
#2 Re: Sticking the Bonnet on a Spit Rotisserie
Post by Polse7317 » Thu Feb 01, 2018 5:47 pm
Bravo, Well done :salute:
#3 Re: Sticking the Bonnet on a Spit Rotisserie
Post by Gfhug » Fri Feb 02, 2018 11:31 am
Yves, I'm waiting for Rory to finish with it and then he can post it to me :lol:
In truth I wish I had welding experience to make up some of the helpful assemblies Rory makes. :yellow:
rfs1957
#4 Re: Sticking the Bonnet on a Spit Rotisserie
Post by rfs1957 » Fri Feb 02, 2018 1:09 pm
You can have the adapter bits that fix to the bonnet for the cost of the postage when I've finished, guess between now and April maybe ? Then all you need to do is find yourself a bit of pipe.
I'm just a bit disappointed nobody's gagging to pinch my engine stand, for that really is progress ......
viewtopic.php?f=3&t=11938
#5 Re: Sticking the Bonnet on a Spit Rotisserie
Post by Gfhug » Fri Feb 02, 2018 3:33 pm
OK, Rory, I'll have that too! :wink:
Actually, it is another fine piece of work. I would tend to send an engine away for anything above taking the head off, so maybe I'll pass for the moment.
ATB
mark10337
Switzerland
#6 Re: Sticking the Bonnet on a Spit Rotisserie
Post by mark10337 » Sat Feb 03, 2018 9:29 pm
I would definitely be interested in the engine stand, although I didn't think it would even be for sale. I've got the opportunity to get hold of a used engine and had been wondering what I would do for a work stand for it.
-Mark
rfs1957
#7 Re: Sticking the Bonnet on a Spit Rotisserie
Post by rfs1957 » Sun Feb 04, 2018 12:50 pm
Mark, whilst the block is at Chesman I don't need the engine crab, it'll be a couple of months probably. So for the cost of the postage you can have it for that time. You need to make sure that the throat of whatever Machine-Mart or Clarkes engine stand you use has a 60mm bore, my stand is MM but is at least 25 years old. You will then be able to see if you like it, see how much the holes need filing to fit another engine, and even show it to a general metal-fabricator to get a copy made ?
