#1 Squeaky Steering/Rack Mount Replacement
Posted: Sat Feb 03, 2018 9:16 pm
When I recommissioned my car I changed all the rubber bits including the steering rack mounts. These were the standard items and I did it when I did my LHD/RHD conversion. That was 2 years ago.
You can buy standard/soft (metalastic), firmer (polybush) and very firm (solid). Mine were the soft ones.
One thing that has always bothered me (pointed out by my MOT tester) is that with the car on the ground and the bonnet open, the soft rubber mounts allow the steering rack to move about and inch side to side. Not exactly what a "sporting young man" wants.
With an assistant turning the wheel, have a look at your rack with the bonnet open and you might see what I mean.
So I splashed out £80 for a pair of polybush mounts and thought I would tell you what kind of a job it is to change them if you are interested.
Took me about 3 hours.
Here is the car.
Here is a soft rubber mount in situ. There are two of course, one either side.
Here is the steering column lower UJ marked with green paint in the hope I put it back together as it came apart, otherwise I will have to re center the steering wheel.
Here are is an old mount with the fiddly nuts and bolts removed. 3 nuts on captive studs, one nut and bolt and two "failsafe" nuts and bolts with crush tubes one the drivers side. The track rod ends need to be undone to allow the rack to move.
On the other side the failsafe bolts have flat washers and lock-nuts. These take a while to undo with the bonnet and the wheels on the car as clearance is tight for fingers and spanners.
Here is the rack pulled out of the way just enough for the mounts to be fiddled out. The lower radiator hose needs to be moved out of the way for clearance to allow the rack to slide around enough. Its all pretty tight (as usual).
Here are the new mounts in place a few nuts and bolts to do.
Here is a new mount in place. Job almost done.
That was it for today. Tomorrow I intend to drop the steering column at the top to make more clearance through the bulkhead to get rid of the annoying squeek on the rubber grommet every time I turn the wheel.
I will also be able to report on steering rack movement. If it is dry I might even be able to have a test drive with my new "sharpened" steering.
Here is the car.
