My car is running very well on a standard engine with my Emerald ECU and Jenvey throttle bodies. So I thought I had better try and mess it up.
To that end, I have got off to an excellent start by purchasing a broken cylinder head from a fuel injected S3 XJ6.
I dropped it of at Johns secret shed (the XK/Aston guru). Yesterday for an inspection.
It looked ok yesterday when I picked it up and handed over the dosh to the seller.
However all my dreams of a cheap quick rebuild were quickly destroyed by 9.30am when John rang me up and told me it needed welding. What do you expect when you buy 32 year old cylinder head I suppose.
He thinks 2 of the valve seat holes look dodgy.
Maybe 2 out of three valve seats have porous material behind them that have allowed water though causing a bit of alloy erosion.
So rather than give up, the otherwise OK head is off to Spalding to be welded and machined, by more top secret engineers who do this sort of thing in their sleep.
Welding and new valve seats, maybe some porting? Then back to John.
The plan is to pull the manifolds off my car, remove the complete head and do a swap in a weekend. I dont like idea of it lying around in bits.
Then I intend to drive over to Emerald for a remap so I can see the power increase (or not) with the same set up.
Theses later head have larger inlet valves and the fuel injection cams give higher lift.
Then the esteemed forum members will know whether all this shenanigans is actually worth it!
Apparently.
