#1 S1 4.2 Carb & Inlet Manifold Rebuild.
Posted: Wed Mar 28, 2018 9:04 am
by eTypeG
I have had the carbs rebuilt and inlet manifold cleaned/polished up, etc. I am trying to install new adaptors into the inlet manifold (brake servo, heater outlet and temp sender unit) but finding them very tight i.e. only going in a thread or two by hand. Is this normal or should they go in fully by hand ?
#2 Re: S1 4.2 Carb & Inlet Manifold Rebuild.
Posted: Sun Apr 01, 2018 9:23 am
by ETTony
I have recently replaced the brake vac nipple on the inlet m'fold. Needed a deep socket to get a good fit, once started, it came out easily.
The new nipple only managed a few turns by finger then needed a socket (a deep throat wheel nut) the rest of the way. it is a parallel thread.
#3 Re: S1 4.2 Carb & Inlet Manifold Rebuild.
Posted: Sun Apr 01, 2018 8:26 pm
by eTypeG
Many thanks for the reply, I am worried about cross threading.
#4 Re: S1 4.2 Carb & Inlet Manifold Rebuild.
Posted: Sun Apr 01, 2018 9:09 pm
by ETTony
It is a course thread, unc ?. I used a dab of grease and it went well in smoothly
