#1 Inner fulcrum needle bearings
Posted: Fri Mar 30, 2018 6:29 pm
by valley7
As part of my exponentially growing rear brake job, I noticed that the needle bearings on my inner fulcrums are in poor condition. Can I just push the pair out at the same time with a press or do I need a blind bearing puller / slide hammer?
#2 Re: Inner fulcrum needle bearings
Posted: Fri Mar 30, 2018 7:17 pm
Yes push out together they should press out fairly easy.....a couple of sockets and a vice is enough..... Steve
#3 Re: Inner fulcrum needle bearings
Posted: Fri Mar 30, 2018 11:16 pm
Or just tap them out with a screwdriver or punch and a hammer.
Be aware that you should replace the sleeves that the bearings run on as well.
The more jobs you do while the IRS is out the better IMO.
