#1 Steering shaft bent
Posted: Fri Apr 06, 2018 4:41 pm
Hello
I thought it might be normal as the E Type has no servo. My steering wheel on my 4.2 gives me the impression that it is "locking in".
Also, turning the steering wheel with open bonnet, I can see the tie rod end and rack moving up and down by a total of about 1 cm. Ok we have the rubber mount on the picture frame, but 5 mm in each direction looks a bit wrong.
I do have a spare steering shaft but that als has a slight curve.
Would a straight shaft eliminate this odd feeling and can a steering shaft be straightened?
Not sure if I want to try it as it could also get worse.
Who of you has or had the same experience and how did you resolve it?
Many thanks
Maikel
Many thanks
Maikel
