Steering shaft bent
Maikel
#1 Steering shaft bent
Post by Maikel » Fri Apr 06, 2018 4:41 pm
Hello
I thought it might be normal as the E Type has no servo. My steering wheel on my 4.2 gives me the impression that it is "locking in".
Also, turning the steering wheel with open bonnet, I can see the tie rod end and rack moving up and down by a total of about 1 cm. Ok we have the rubber mount on the picture frame, but 5 mm in each direction looks a bit wrong.
I do have a spare steering shaft but that als has a slight curve.
Would a straight shaft eliminate this odd feeling and can a steering shaft be straightened?
Not sure if I want to try it as it could also get worse. :hammerdrill:
Who of you has or had the same experience and how did you resolve it?
Many thanks
Maikel
#2 Re: Steering shaft bent
Post by mgcjag » Fri Apr 06, 2018 4:50 pm
Hi Maikel......Are the wheels on the ground when the bonnet is up...or are they hanging down......if down do you have the modified track rod ends with the extra angular movement.....I think your steering rack mounts sounds like too much movement have they delaminated.... Also disconnect the universal joint at the bottom of the steering shaft and then turn your steering wheel to see if you have any bend in the shaft... Steve
Maikel
#3 Re: Steering shaft bent
Post by Maikel » Fri Apr 06, 2018 5:40 pm
Hi Steve,
The wheels are on the ground when I turn the steering and the rubber mounts are moving up an down.
The plate towards the picture frame is fixed but the rubber and the front plate is moving.
I read somewhere that there is some movement but maybe not that much.
I do not feel anything on bumpy roads.
Mainly on smooth tarmac and straight road.
Maikel
#4 Re: Steering shaft bent
Post by mgcjag » Fri Apr 06, 2018 6:20 pm
Definatly sounds like your mounts need replaceing....a friend of mine was still driving his and didnt notice any problem but both mounts had delaminated and were only held on by the safety bolts.... Steve
Tbob
#5 Re: Steering shaft bent
Post by Tbob » Fri Apr 06, 2018 7:52 pm
I straightened my steering shaft, it was bent about the same amount. Just used a press and some gentle nudging. Checked it with a straight edge.
Bob t
Maikel
#6 Re: Steering shaft bent
Post by Maikel » Fri Apr 13, 2018 4:40 pm
Here is a video of the rack mounting movement
Steering rack rubber mounting movement
It gives you the locking feeling which does not feel nice
JerryL770
#7 Re: Steering shaft bent
Post by JerryL770 » Fri Apr 13, 2018 7:41 pm
You can see that the rubber moves with the moving plate of the flexible mount, so the mount is OK.
Definitely need a straight shaft. It may be that the universal joint also is stiff.
Jerome Lunt
