#1 Can windscreen chrome trims be reshaped?
Posted: Sat Apr 28, 2018 9:11 am
by Jeremy
During the chroming process my A post exterior chrome trims became somewhat flattened. It must have been the heat generated by the polishing. So now they don't follow the curve of the roof line and of the (newly fitted) windscreen rubber. Is it possible to reshape them? I have no panel beating skills or tools, and would probably end up kinking them and/or cracking the chrome. Or should I swallow hard and buy new ones?
Grateful for any advice, as always.
#2 Re: Can windscreen chrome trims be reshaped?
Posted: Sat Apr 28, 2018 10:27 am
by malcolm
I know they can, but not sure of the best way to do it. I'll wait for answers with interest, because mine don't fit well either! I suspect many don't.
#3 Re: Can windscreen chrome trims be reshaped?
Posted: Sat Apr 28, 2018 1:53 pm
by ALAN COCHRANE
I’ve just reshaped the passenger side A post chrome by hand. The chrome is very thin and can be bent a little at a time to avoid the chrome finish cracking.
I mananaged to achieve a very good fit, in fact it’s better than the driver’s side now.
Obviously this was done with the chrome off the car.
Alan
#4 Re: Can windscreen chrome trims be reshaped?
Posted: Sat Apr 28, 2018 1:58 pm
by Jeremy
Did you just do it with your bare hands Alan, or use tools?
#5 Re: Can windscreen chrome trims be reshaped?
Posted: Sat Apr 28, 2018 6:15 pm
by ALAN COCHRANE
Just my own two hands, no tools at all. The metal is too thin to withstand any mistreatment. Just bend it a little at a time and keep moving around the "foot" bending as you go.
I'm assuming it's the bottom of your chrome that's sticking out?
Alan
#6 Re: Can windscreen chrome trims be reshaped?
Posted: Sat Apr 28, 2018 10:00 pm
by Jeremy
Yes, the foot sticks out a bit. I'm also not sure how snugly the rearmost point at the top should fit into that recess under the "eaves" of the roof...should the trailing edge of the trim be touching the inside edge of the gutter, or should it sit nearer the A post and leave a gap with the gutter?
Bending that top bit is actually pretty difficult as the curved edges make it quite rigid. But I'll go v carefully. Thanks Alan.
#7 Re: Can windscreen chrome trims be reshaped?
Posted: Sun Apr 29, 2018 8:27 am
by malcolm
Yes, thanks Alan. How is the chrome trim attached?
#8 Re: Can windscreen chrome trims be reshaped?
Posted: Sun Apr 29, 2018 12:04 pm
by ALAN COCHRANE
Jeremy
I only had to bend the foot of the chrome to get it to fit, but I think the section that fits up the side of the windscreen would respond in the same way. The top of the trim fits under the cap at the top of the A post. I removed this before taking off the side trim.
The windscreen side trim is attached by three rivets into the return face of the A post. The holes may be partially hidden by the door glass rubber seal.
Alan
#9 Re: Can windscreen chrome trims be reshaped?
Posted: Sun Apr 29, 2018 1:52 pm
by Series1 Stu
Alan,
Are you at crossed purposes here? I think Jeremy's car is a FHC and yours is an OTS and they are different. There are no fixings on the FHC. They're just bonded on with lots of goop! I've seen them fixed with self tapping screws into the seal but they look really ugly.
#10 Re: Can windscreen chrome trims be reshaped?
Posted: Sun Apr 29, 2018 2:22 pm
by ALAN COCHRANE
Yes you're right. I've just seen both Malcolm & Jeremy's signatures and both have a FHC.
Despite that the windscreen side trim looks the same apart from an extra piece along the top. I would think it will be of a similar thickness and can be bent by hand.
I'm surprised the trim isn't riveted to the A post as on the OTS. There doesn't appear to be any reason for it not to looking at images of this area.
Sorry for the confusion.
Alan
#11 Re: Can windscreen chrome trims be reshaped?
Posted: Sun Apr 29, 2018 2:49 pm
by Durango2k
Iirc mine was also just bonded. Series 1 2+2.
Will check...
Carsten
#12 Re: Can windscreen chrome trims be reshaped?
Posted: Sun Apr 29, 2018 8:55 pm
by Series1 Stu
ALAN COCHRANE wrote: ↑Sun Apr 29, 2018 2:22 pm
Yes, it's an odd piece of design. They are thin and flimsy and can be easily bent and formed to shape. That's the problem when your send them off for re-chroming. They come back a different shape to how they started.
#13 Re: Can windscreen chrome trims be reshaped?
Posted: Mon Apr 30, 2018 8:39 am
by malcolm
Pretty sure now that mine is bonded - but thanks anyway Alan.
#14 Re: Can windscreen chrome trims be reshaped?
Posted: Mon Apr 30, 2018 3:11 pm
by Jeremy
All the trims are def held in place only with black goo. How to press them in place while it sets is another darn good question. Someone on here used a load of sucker clamp things on the glass IIRC?
#15 Re: Can windscreen chrome trims be reshaped?
Posted: Mon Apr 30, 2018 3:48 pm
You need window suction clamps like these...ideal for the job....Steve
https://www.ebay.co.uk/i/152772718751?c ... 1ffffccee6
#16 Re: Can windscreen chrome trims be reshaped?
Posted: Mon Apr 30, 2018 4:49 pm
by Polse7317
#17 Re: Can windscreen chrome trims be reshaped?
Posted: Mon Apr 30, 2018 6:27 pm
by Jeremy
Thanks for the tip Steve. I've ordered a set.
#18 Re: Can windscreen chrome trims be reshaped?
Posted: Mon Apr 30, 2018 6:28 pm
by Jeremy
And thanks for the pictures Yves. Very helpful!
