Inertia seat belts
rubyfloriley
Topic author - Posts: 61
#1 Inertia seat belts
Advice please,
My series 2 roadster had inertia reel seat belts that were mounted on the rear bulkhead which has been replaced i read a thread where the belts had been mounted inside the boot which seems a very good idea are there any downsides to doing this,and are there hole/slot liners to stop the belt chaffing on the slot edges or does one have to make them.
Many thanks for any comments.
Regards Brian
Regards Brian
#2 Re: Inertia seat belts
Brian -
I have no experience of using the belts inside the boot but I believe these people make the fitting you need to tidy up the slot. https://www.quickfitsbs.com/index.php
Joe
Joe
1963 3.8 OTS
rubyfloriley
#3 Re: Inertia seat belts
Joe
Many thanks will look them up.
Brian.
Brian.
#4 Re: Inertia seat belts
Hi Brian....the part to tidy the hole is called a seat belt escutcheon....just google lots of options.....CMC at Bridgenorth have very nice chrome escutcheons i have a pair fitted.... Steve
rubyfloriley
#5 Re: Inertia seat belts
Steve,
Brian.
Brian.
rubyfloriley
#6 Re: Inertia seat belts
Can you recommend a supplier of inertia seat belts for a series 2 roadster. Quick fit safety belt advertise a belt for each model but without seeing it its difficult to visualise.
Any thoughts.
Brian.
Any thoughts.
Brian.
#7 Re: Inertia seat belts
Hi Brian...i used http://www.fdts-seatbelts.co.uk there website isnt very good but if you phone them and ask for Sue....she will send samples of webbing and photos of fittings.....my inertia belts i had made there are very good .. unfortunatly cant photo mine as iv fitted them in the inner wing.. Steve
#8 Re: Inertia seat belts
I'd recommend speaking to Sue at FDTS, very helpful and made up a very good set of inertias for my FHC. Being skinny I needed a better option than the stalk to clip the belt into which would hold the belt too far forward for me. She made a set with webbing instead, much neater and safer.
#9 Re: Inertia seat belts
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
#10 Re: Inertia seat belts
You smooth talker! Off to OW on Sunday to see the Spit.
rubyfloriley
#11 Re: Inertia seat belts
Thanks for the most helpful replies
Brian
Brian
