#1 Dash & Panel Electrics Advice please
Posted: Tue May 01, 2018 10:52 am
Hi all,
I have been trying to complete the dash/instrument panel wiring on my 63 FHC, prior to getting the dash-top and ventilation hoses installed. As per my last post in the Restoration Stories section, I was making good progress until I started on the final set of connections for the heater blower. The car retains its positive earth config and has a Holden dummy regulator for a Powerlite dynator. I haven't installed their relay (sits between warning light and ign switch) as part of the package yet, until I've got the original ignition setup confirmed.
viewtopic.php?p=101069#p101069
I have since then gone back and tested continuity through the wiring, switches, bulbs, relays & fuses for the following components that have stopped working, using the Coventry wiring book:
1. Choke warning light & switch.
2. Ignition switch & warning light.
3. Flasher switch & relay (using a durite replacement as all bulbs are LED)
All these check out through continuity back to the starter solenoid, control box etc. So I'm confident that the wiring seem ok on paper. However, when I come to put some power into the wiring, I get mixed results.
1. Choke light & switch. When I put power to the green switch wire, earthing through existing earth connection, the light comes on when the switch is activated. Replacing the green switch wire into its 3 way connector and putting power into the connector, it no longer works! The connector came as part of the loom and was 'pre-wired' with the Fuse 7 feed, the flasher relay feed and the reverse lamp feed. By process of elimination, it seems the Fuse 7 feed is the connection that stops the choke light working. This may be 'normal' based on where I'm applying the power - my auto electrics experience doesn't reach that far (or very far at all to be honest). Applying power at the Fuse 7 connection (fuse is ok) also results in it not working.
The wiring diagram shows a slightly different wiring config for this connector. It shows four connections, the fourth being the Fuel level warning lamp green wire as well, however the green wire from the lamp disappears into the wiring loom and reappears at fuse 7.
2. Flasher switch & bulbs. With the power applied at the 3 way, the indicator warning bulbs and the indicators lit independently in line with the switch control, but didn't flash.
3. Applying power to the ignition switch brown/white feed and turning the key to 'on', lit the warning light. That seems ok at the moment, but when I apply power at the starter solenoid and switch it on, there is no ign light coming on and the stop lamps and panel lights which light via the lighting switch on the panel, go out!
Can anyone shed any light (pun intended) on where I am going wrong with my testing?
