#1 RnR crank or replacing crank
Posted: Wed May 02, 2018 7:57 pm
by mister mitch
Is there way to clear the lower timing chain so I can remove the crank???
I have already removed the timing cover without pulling the head plus the damper and its cone…
If I could just take the lower timing chain off its sprocket on the crank…thereby clearing the crank…
1969 E Type 2+2 stock 6 cylinder federated
Thanks Mitch
#2 Re: RnR crank or replacing crank
Posted: Wed May 02, 2018 8:38 pm
by politeperson
John (my machinist) took the crank out of my engine for machining 2 weeks ago without removing the timing case.
This was to fit modern lip seals. The rest of the motor was pretty new.
We split the chain and added a removable link when we put it back together.
Runs fine now.
