Hi guys,
Has anybody had experience using Castrol Dot 4 Synthetic Brake Fluid? Not really sure about the "synthetic" bit. Is this like silicone or the standard brake fluid?
Grateful for any replies. Many thanks.
George
Castrol Dot Synthetic Brake Fluid
gmunro
Topic author - Posts: 119
#2 Re: Castrol Dot Synthetic Brake Fluid
No experience with this one but DOT 4 isn't Silicone.
The silicone is DOT 5
Mich
Mich
Michel
gmunro
#3 Re: Castrol Dot Synthetic Brake Fluid
Thanks Mich. Trying to find out exactly what "Synthetic" fluid is.
Cheers,
George
Cheers,
George
1967 Series 1 OTS
#4 Re: Castrol Dot Synthetic Brake Fluid
George...just try a quick google search....i just did ....the first thing that came up was...All DOT3 & DOT4 fluid is synthetic...ie it is man made and does not have a petroleum base. DOT3 & 4 can safely be mixed.
However its from the net so is it true....i would do a bit of research... Steve
Geoff Green
#5 Re: Castrol Dot Synthetic Brake Fluid
3,4,5.1 are organic esters and considered synthetic
5 is silicone and I would also consider it to be synthetic
gmunro
#6 Re: Castrol Dot Synthetic Brake Fluid
Steve and Geoff,
Many thanks for your very speedy replies. Steve, I will go down your suggested route and start with Google and then head on from there. Again, Many thanks. George
1967 Series 1 OTS
#7 Re: Castrol Dot Synthetic Brake Fluid
Hi George
After having a leak on my brake fluid reservoir which took all my paint of the bulk head I had it replaced with this
I haven’t noticed any difference with the brakes and if it leaks again I’m not going to have the hassle of repainting the bulk head.
1968 series 1.5 fhc, Ftype S for when it rains
#8 Re: Castrol Dot Synthetic Brake Fluid
Lots more about the mysteries of brake fluid and some views on their merits...
viewtopic.php?f=3&t=12262&hilit=Brake+fluid
