#1 Brake Warning Light
Posted: Mon Jun 04, 2018 2:53 pm
Hi Everyone
Since my engine and gearbox adventure last winter I've had problems with the brake warning light failing to extinguish. This is due to the transmission tunnel sitting slightly higher over the new gearbox cover and consequently stopping the handbrake lever resting in as low a position.
Even before this the handbrake lever had to rest on top of the tunnel before the light would go out. One ratchet position up and it came on. I can still lower the lever past the last ratchet position but not as far as before. At this slightly higher position the handbrake is still disengaged.
I've eliminated the brake fluid reservoirs as the culprit so there's no safety issue involved.
So before I remove the tunnel can anyone tell me if the switch on the mechanism can be adjusted?
Alan
Alan
