These are mentioned in the factory fit section by David Jones.
I have them on my gear lever linkage but they are mentioned on the clutch pivot pin adjuster and on the accelerator linkage fulcrum lever and I’m not sure exactly to what this refers?
Can anyone expand on this please?
Robbie
Thackery spring washers
#1 Thackery spring washers
#2 Re: Thackery spring washers
You are correct in that they are in those positions.
#3 Re: Thackery spring washers
Sorry misread your post. There is one where the clutch fork attaches to the slave cylinder pushrod, and one on the triangular bit of the throttle linkage on the firewall in front of the driver.
#4 Re: Thackery spring washers
Thanks Andrew
Robbie
Robbie
