Alternator Bracket
andyf
#1 Alternator Bracket
Post by andyf » Thu Aug 09, 2018 4:27 pm
I have lost a bolt that holds the alternator bracket to the engine block. (See attached photo. It is just to right of the crease in the heat shield, .) Can any one tell me the size and length of this bolt? I can’t find reference to it in SNG catalogue.
Many thanks in anticipation.
Andy '69 Series 2 2 plus 2
#2 Re: Alternator Bracket
Post by Heuer » Thu Aug 09, 2018 4:45 pm
The bolt is UFB131/26R or UFS137/6R (LH side) and you can use this document to decode the spec. It is from our Knowledge Base:
Jaguar Nuts, Bolts and Fasteners specs: https://www.dropbox.com/s/vbkgbwl4b3tyc ... s.pdf?dl=1
andyf
#3 Re: Alternator Bracket
Post by andyf » Thu Aug 09, 2018 7:04 pm
Great, thanks for prompt response. Have ordered from SNG (about 70pence). Cost more in postage!
andyf
#4 Re: Alternator Bracket
Post by andyf » Tue Aug 14, 2018 12:51 pm
Just to let you know the bolt as referenced was incorrect. It is the correct length but slightly too "narrow"
The correct bolt (left hand side alternator bracket bolt to block) is UFS143/6R, superseded for ordering purposes by SH607061J. There are 2 identical bolts holding the bracket to the block.
Hope this is useful!
