#1 Triple SU rebuild
Posted: Sun Aug 19, 2018 1:31 pm
Dear All
Just having fun stripping and cleaning my S1 SU carbs
Couple of things
1. Slow run valves: when I unscrewed them I found they had no brass washer or rubber washer fitted as described in the SU blurb. Are these essential? I’m thinking they probably are?
2. The jag parts handbook lists a large washer that sits at the base of the dashpot spring...I didn’t have these ...Again are they important and available?
3. The Centre carb choke mechanism has a double holed lever but mine is broken...it looks like there’s a pin you have to drive out to release it from the spindle to then be able to replace it..had anyone done this?
4. How much play is allowed in the butterfly valve spindle before resleeving..I have s minute amount only
Robbie
Couple of things
Robbie
