Prop shaft UJs
Robbiee
#1 Prop shaft UJs
Post by Robbiee » Fri Aug 31, 2018 8:49 pm
Dear friends
I’m fitting newprop shaft UJs to my S1 3.8 850456
They go in fine BUT there’s a lot of lateral play even when circlips are in place(see photos)
So I checked ....
Ordered from SNGB over phone because of multiple options, told them the car chassis number etc
They are part number 46 which appear to be for an earlier prop shaft...damn
Mine should be the next type but are listed as no longer available when searching on the website in the S1 Etype section however if I enter 8405 (the correct number according to the jag spare parts catalogue)in the search box I get a hit and they ARE available!!
I guess I remove them and phone up to get a swap?
Is 8405 correct???
HELP
Thanks in anticipation
Robbie
Robbiee
#2 Re: Prop shaft UJs
Post by Robbiee » Fri Aug 31, 2018 9:13 pm
Photo of box!
They’re GKN
Robbiee
#3 Re: Prop shaft UJs
Post by Robbiee » Fri Aug 31, 2018 9:20 pm
Interestingly 8405 is listed as backorder only and Etype is not on the list of cars suggested!
Would 9409 ( the 3rd type listed) be OK for my car??
Robbie
JagWaugh
Switzerland
#4 Re: Prop shaft UJs
Post by JagWaugh » Sat Sep 01, 2018 4:31 am
Find your local GKN driveline shop and take your old U/Js in. They may even have them in stock.
I normally just take the shaft in and have them do it. Usually 1-3 day turnaround, and it comes back with new U/Js, balanced and painted.
Robbiee
#5 Re: Prop shaft UJs
Post by Robbiee » Sat Sep 01, 2018 5:49 am
That sounds like a good solution
Robbie
